Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 2
With wire cutters or scissors, carefully strip the outer cable covering. Cut just the outer cover of the cable, and make sure to cut all the way around. Don't cut any of the internal wires. Pull on the piece of cover that you've separated from the rest. You should be left with  four exposed individual wires.
  • With wire cutters or scissors, carefully strip the outer cable covering.
  • Cut just the outer cover of the cable, and make sure to cut all the way around. Don't cut any of the internal wires.
  • Pull on the piece of cover that you've separated from the rest. You should be left with four exposed individual wires.
  • There should be four wires, and occasionally a piece of string too. If there are fewer wires, then you've clipped one off, and you need to trim the others and try this step again.
  • If there are more than 4 wires, you probably have a USB 3.0 cable. In this case, make sure that whatever wires you'll be reconnecting are both USB 3.0.
Hier Übersetzung einfügen
