Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 3
Strip all the wires from both cables. You'll need about 1/8” – 1/4”, or about 1/2 cm of exposed copper wire. If you have a wire stripper, the wires will likely be 28 gauge, though they could sometimes be 26 gauge.
  • Strip all the wires from both cables. You'll need about 1/8” – 1/4”, or about 1/2 cm of exposed copper wire.
  • If you have a wire stripper, the wires will likely be 28 gauge, though they could sometimes be 26 gauge.
  • If you don't have a wire stripper, you can strip the wires exactly the same way as you exposed these wires: use wire cutters or scissors to gently cut the outer insulation, then pull off the insulation.
  • When stripping wires, do not cut or damage the copper wires. If you do damage the wire, cut off the damaged portion and try again.
Hier Übersetzung einfügen
