Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 7
Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass. Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass. Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass.
  • Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
  • Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass.
Schiebe das Plektrum entlang der oberen Kante des Handys zum Trennen des Klebers, welcher die Glas-Rückabdeckung sichert.
Führe das Plektrum langsam und vorsichtig um die Ecken des Handys. Der gebogene Teil des Glases am linken und rechten Rand kann sehr leicht springen, wenn das Pick dagegen drückt.
