Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5
Use the plastic opening tool to pry the top panel up from the base of the computer. Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base. Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
  • Use the plastic opening tool to pry the top panel up from the base of the computer.
  • Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
  • Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
  • Disconnect ribbons, and slowly lift the top panel up, away from the base.
Hier Übersetzung einfügen
