Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
During this procedure, keep all fasteners as, they will be reused during re-assembly. Loosen socket head screws securing the X-Axis belt idler using an M3 hex. Push the X-Axis belt idler towards the left to loosen the belt tension.
Top Section 1a.
  • During this procedure, keep all fasteners as, they will be reused during re-assembly.
  • Loosen socket head screws securing the X-Axis belt idler using an M3 hex.
  • Push the X-Axis belt idler towards the left to loosen the belt tension.
  • The X-Axis idler can also be removed
  • Remove the belt ends from the X-Axis carriage.
  • Note how the belt loops around the the tabs and re-install the same later. There is no need to fully remove the belt. Instead, just let both ends hang freely until re-assembly.
  • Loosen the fasteners holding the bottom wheel in place using the double sided wrench and M3 hex until the . Do not fully remove the nut.
  • Remove button screws using an M2 hex.
Hier Übersetzung einfügen
