Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 9
Insert properly configured sd card into the slot on the display. Make sure the power switch is set to "0" then plug the power cable into your machine. Position the machine so you can see the screen and turn the power switch ON. If everything goes correctly, you will see files load, images flash then "END" at the top. See the next step for a video.
Flash the Screen Files
  • Insert properly configured sd card into the slot on the display.
  • Make sure the power switch is set to "0" then plug the power cable into your machine. Position the machine so you can see the screen and turn the power switch ON.
  • If everything goes correctly, you will see files load, images flash then "END" at the top. See the next step for a video.
Hier Übersetzung einfügen
