Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 11 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel. Do not insert your spudger between the plastic strip and the rear bezel. With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
  • Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
  • Do not insert your spudger between the plastic strip and the rear bezel.
  • With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
  • Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Hier Übersetzung einfügen
