Englisch
Deutsch
7. Schritt
The next few steps will require you to separate the LCD from the adhesive applied to the upper and lower edges of the front bezel.
  • The next few steps will require you to separate the LCD from the adhesive applied to the upper and lower edges of the front bezel.
  • The adhesive is applied such that it sticks to a thin steel strip around the perimeter of the LCD. When prying your LCD away from the front panel, be sure you are separating the front panel from the steel strip on the LCD.
  • Do not simply pry on the edge of the frame as it is made of aluminum and can very easily bend!
  • Use the flat end of a spudger to gently lift one of the top corners of the LCD out of the front bezel.
Hier Übersetzung einfügen
