Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 7
Use a 9/16-inch wrench to remove the three engine mount nuts and the ground wire at the front of the engine. Place a hand underneath the frame to catch the carriage bolts as you remove the nuts. The engine mount bolt with two nuts and a ground wire (shown on the left side of the first photo in this step) is longer than the other bolts securing the engine. During reassembly, make sure to reuse the longer bolt on the correct side and reinstall the ground wire between the two nuts.
Remove the Engine Mount Nuts and Bolts
  • Use a 9/16-inch wrench to remove the three engine mount nuts and the ground wire at the front of the engine.
  • Place a hand underneath the frame to catch the carriage bolts as you remove the nuts.
  • The engine mount bolt with two nuts and a ground wire (shown on the left side of the first photo in this step) is longer than the other bolts securing the engine. During reassembly, make sure to reuse the longer bolt on the correct side and reinstall the ground wire between the two nuts.
Hier Übersetzung einfügen
