Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Remove the blue tape that secures the white antenna cable to the battery. Using a spudger, carefully disconnect the white antenna cable.
Battery removal
  • Remove the blue tape that secures the white antenna cable to the battery.
  • Using a spudger, carefully disconnect the white antenna cable.
  • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
  • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
  • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
Hier Übersetzung einfügen
