Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Step 1
Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover. The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away. The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
  • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
  • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
Hier Übersetzung einfügen
