Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 9
With the pOLED display removed, we're a bit dismayed that the battery comes with it. Prying against this flexible sheet for a battery swap doesn't seem ideal, even if the battery is in a metal caddy. Nine steps in we finally have both batteries: This yellow rectangle packs slightly more punch, at 1265 mAh and 4.8 Wh, than the wafer-thin 4.7 Wh cell we extracted earlier. The batteries add up to Motorola's claim of 2510 mAh, or 9.7 Wh of power. For comparison, just one of the Galaxy Fold batteries has about the same capacity of both of these things put together. The giant L-shaped iPhone XS Max battery manages to dwarf them all at 3969 mAh, or 15.04 Wh.
  • With the pOLED display removed, we're a bit dismayed that the battery comes with it. Prying against this flexible sheet for a battery swap doesn't seem ideal, even if the battery is in a metal caddy.
  • Nine steps in we finally have both batteries: This yellow rectangle packs slightly more punch, at 1265 mAh and 4.8 Wh, than the wafer-thin 4.7 Wh cell we extracted earlier.
  • The batteries add up to Motorola's claim of 2510 mAh, or 9.7 Wh of power. For comparison, just one of the Galaxy Fold batteries has about the same capacity of both of these things put together. The giant L-shaped iPhone XS Max battery manages to dwarf them all at 3969 mAh, or 15.04 Wh.
  • The pOLED display (allegedly a BOE screen, potentially using LG Display technology) isn't giving up many secrets—but we do spy some Samsung tech:
  • Samsung S6SY77CX, likely an iteration of Samsung's popular touch controller.
Das pOLED Display ist ausgebaut und wir sind ein bisschen konsterniert, dass der Akku gleich mit raus kommt. Es erscheint uns nicht gerade ideal, dass man bei einem Akkutausch gegen diese flexible Platte hebeln muss, selbst wenn der Akku in einer Metallbüchse sitzt.
Nach neun Schritten haben wir endlich beide Akkus: dieses gelbe Rechteck ist mit 1265 mAh und 4,8 Wh etwas leistungsstärker als die hauchdünne 4,7 Wh Zelle, die wir vorhin herausgeholt haben.
Zusammen ergeben die beiden Akkus die von Motorola angegebene Leistung von 2510 mAh oder 9,7 Wh. Zum Vergleich hat einer der Galaxy Fold Akkus etwa die gleiche Leistung wie beide dieser Teile zusammen. Der L-förmige Monsterakku im iPhone XS Max kann sie allerdings alle mit seiner Leistung von 3969 mAh oder 15,04 Wh in die Tasche stecken.
Das pOLED Display (angeblich ein BOE Bildschirm, der möglicherweise LG Display Technologie nutzt) gibt nicht viele Geheimnisse preis, aber wir entdecken etwas Samsung Technologie:
Samsung S6SY77CX, wahrscheinlich eine Iteration des beliebten Touch Controllers von Samsung.
