Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side. Rotate the screen 180° and remove the other two screws. You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
  • Rotate the screen 180° and remove the other two screws.
  • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
Hier Übersetzung einfügen
