Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 5
Just like its predecessor, the A51 also features an optical in-display fingerprint scanner which is placed near the daughterboard. Optical fingerprint sensors work by illuminating the finger and taking an image of the bright and dark areas representing the ridges and valleys of the fingerprint. (More on fingerprint sensor technology.) The daughterboard comes out without a fuss and brings the USB-C plug and the beloved 3.5 mm audio jack to light.
  • Just like its predecessor, the A51 also features an optical in-display fingerprint scanner which is placed near the daughterboard.
  • Optical fingerprint sensors work by illuminating the finger and taking an image of the bright and dark areas representing the ridges and valleys of the fingerprint. (More on fingerprint sensor technology.)
  • The daughterboard comes out without a fuss and brings the USB-C plug and the beloved 3.5 mm audio jack to light.
  • A dedicated audio jack reduces wear and tear on the USB-C port, which is nice. Both ports are soldered in place though, so replacing one individually will require soldering skills.
  • That said, this configuration is better than the single-board Galaxy S10! At least this tiny daughterboard can be swapped out with relative ease should one or both ports fail on you.
Wie sein Vorgänger verfügt auch das A51 über einen im Display integrierten optischen Fingerabdruckscanner, der sich nahe am Daughterboard befindet.
Optische Fingerabdrucksensoren beleuchten den Finger und machen ein Bild von den hellen und dunklen Bereichen, die die Oberfläche des Fingerabdrucks darstellen. (Mehr zur Technologie von Fingerabdrucksensoren findest du hier.)
Das Daughterboard lässt sich problemlos ausbauen und bringt auch gleich den USB-C Stecker und die heißgeliebte 3,5 mm Kopfhörerbuchse an Licht.
Eine dedizierte Kopfhörerbuchse reduziert den Verschleiß des USB-C Anschlusses, was gut ist. Beide Anschlüsse sind allerdings festgelötet, sodass ein individueller Austausch Lötkenntnisse erfordert.
Im Großen und Ganzen ist diese Konfiguration jedoch besser als die des Galaxy S10 mit nur einer Platine! Wenigstens kann dieses winzige Daughterboard relativ leicht ausgetauscht werden, falls einer der Anschlüsse oder auch beide kaputt gehen.
