Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass. Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass. After being cut, the adhesive will sometimes stick back together as it cools. To prevent this you can leave the pick in this edge after cutting, and continue the next steps with a new pick. Repeat this with each edge, leaving a pick and continuing with a new one.
  • Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
  • Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass.
  • After being cut, the adhesive will sometimes stick back together as it cools. To prevent this you can leave the pick in this edge after cutting, and continue the next steps with a new pick. Repeat this with each edge, leaving a pick and continuing with a new one.
Schiebe das Plektrum um den kompletten unteren Rand herum, um durch den Kleber zu schneiden, der die Glas-Rückabdeckung sichert.
Führe das Plektrum langsam und vorsichtig um die Ecken des Handys. Der gebogene Teil des Glases am linken und rechten Rand kann sehr leicht springen, wenn das Plektrum dagegen drückt.
Nachdem der Kleber durchtrennt ist, kann er während dem Abkühlen an manchen Stellen wieder zusammenkleben. Lasse das Plektrum in den Rändern stecken, um dies zu verhindern und führe die nächsten Schritte mit einem anderen Plektrum durch. So kannst du den Kleber an allen Rändern lösen.
