Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Orient the laptop so that it is bottom up, and the track pad is closest to you. Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen, but will stay attached to the cover.
  • Orient the laptop so that it is bottom up, and the track pad is closest to you.
  • Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen, but will stay attached to the cover.
  • Slide the blue opening pick along the side of the laptop and pry off the one clip on each side.
  • The cover should easily come off.
Hier Übersetzung einfügen
