Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Using the Phillips #00 head screwdriver, remove the five 4mm screws below the charging port. holding down the motherboard. Remove the two 3mm left most screws. Remove the two 5mm screws that are holding down a silver plate on the charging port in the top right.
  • Using the Phillips #00 head screwdriver, remove the five 4mm screws below the charging port. holding down the motherboard.
  • Remove the two 3mm left most screws.
  • Remove the two 5mm screws that are holding down a silver plate on the charging port in the top right.
  • Remove the silver plate on top of the charging port. This is needed so that the mother board may be removed.
Hier Übersetzung einfügen
