Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Place the projector on its back (buttons down) with the lens facing away from you. Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
  • Place the projector on its back (buttons down) with the lens facing away from you.
  • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
  • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
Hier Übersetzung einfügen
