Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
To replace the DVD mechanism in the BMW MKIV Navigation drive, you will need to start with getting the replacement internal part.  We recommend www.bimmernav.com On the back of the MKIV are a series of stickers.  Any stickers that connect between the top lid and the sides or back need to be removed or cut to allow the top lid to be removed
  • To replace the DVD mechanism in the BMW MKIV Navigation drive, you will need to start with getting the replacement internal part. We recommend www.bimmernav.com
  • On the back of the MKIV are a series of stickers. Any stickers that connect between the top lid and the sides or back need to be removed or cut to allow the top lid to be removed
  • Remove the top lid by lifting up by your fingers. The lid is made of very thin metal and it is best to work slowly around the lid with your fingers to avoid bending the lid
  • Once the lid is removed using the torx 8 driver remove each of the 4 screws carefully trying not to drop or loose these small screws. Screw heads are marked in photos
Hier Übersetzung einfügen
