Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Once the Screws are removed gently lift the dvd mechanism out of the way to reveal the connectors. The Ribbon cable is secured into place with a locking lever. To release it you first have to move the locking mechanism on both sides carefully with a small screwdriver towards the cable as shown in photo.  TAKE NOTE of which end connects to each side as the ribbon cable MUST be reconnected the same direction To remove the power plug gently pull straight up on the power plug to release it from unit.  When replacing the DVD mechanism you will be reusing the power plug and ribbon cable.
  • Once the Screws are removed gently lift the dvd mechanism out of the way to reveal the connectors.
  • The Ribbon cable is secured into place with a locking lever. To release it you first have to move the locking mechanism on both sides carefully with a small screwdriver towards the cable as shown in photo. TAKE NOTE of which end connects to each side as the ribbon cable MUST be reconnected the same direction
  • To remove the power plug gently pull straight up on the power plug to release it from unit. When replacing the DVD mechanism you will be reusing the power plug and ribbon cable.
  • Replacing the new drive is a simply reverse of this process
Hier Übersetzung einfügen
