Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
After removing the plastic cap, remove the screw.  With the keyboard lying on its face, unlock the cable connector by pulling its black plastic locking strip upwards. Then, ease out the connection cable to the keyboard foil (this can be done by inserting a strong pin under the cable and wedging it upwards). After that, you can push the whole inside in the direction of the power button and out of the keyboard frame. Reassamble the other way around: When pushing the inlay back into the frame, make sure the plastic cable to the foils is on the correct side.
  • After removing the plastic cap, remove the screw. With the keyboard lying on its face, unlock the cable connector by pulling its black plastic locking strip upwards. Then, ease out the connection cable to the keyboard foil (this can be done by inserting a strong pin under the cable and wedging it upwards).
  • After that, you can push the whole inside in the direction of the power button and out of the keyboard frame.
  • Reassamble the other way around: When pushing the inlay back into the frame, make sure the plastic cable to the foils is on the correct side.
Hier Übersetzung einfügen
