Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Step 2
Remove the following 14 screws (some models may be missing a couple of screws):
  • Remove the following 14 screws (some models may be missing a couple of screws):
  • One 2.5 mm Phillips.
  • Six 3.5 mm Phillips.
  • One 4.5 mm Phillips near the sleep light with a small shaft.
  • Two 4.5 mm Phillips with larger shafts.
  • Four 5 mm Phillips
  • If a screw is inserted in the left hole, the 14.2 mm screw in step 24 can not be inserted to hold the top case down.
Hier Übersetzung einfügen
