Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
Carefully pull apart the two parts of the exterior frame. Use the spudger to pry apart the two frame components. Once disconnected, the two parts of the frame can be easily separated by using your fingers.
  • Carefully pull apart the two parts of the exterior frame.
    • Use the spudger to pry apart the two frame components.
    • Once disconnected, the two parts of the frame can be easily separated by using your fingers.
    • The rear frame should be removed first.
  • There should be an O-ring on the front face of the camera. Ensure to keep the O-ring with the front part of the frame.
  • The orientation for the pictures is changed in order to properly show which piece is being removed.
Hier Übersetzung einfügen
