Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 153 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 23 übersetzen
Schritt 23
Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad. Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
  • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
  • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
  • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
Halte das iPad an der unteren und oberen rechten Ecke fest und klappe das Frontglas vom iPad weg.
Achte darauf, dass möglicherweise noch Kleber vorhanden sein könnte. Schneide mit einem Opening Pick jeglichen Kleber, der das Front Panel noch unten halten könnte, durch.
[* black] Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
[* icon_caution] Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
[* icon_reminder] During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
