Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Pull the logic board out with a pry stick gently from bottom to top at the current orientation. The ribbon cable will be connected underneath the logic board.  A small amount of force is required to disconnect them. Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
  • Pull the logic board out with a pry stick gently from bottom to top at the current orientation.
  • The ribbon cable will be connected underneath the logic board. A small amount of force is required to disconnect them.
  • Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
Hier Übersetzung einfügen
