Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 16 übersetzen
16. Schritt
Nest Learning Thermostat 2nd Generation Repairability Score: 9 out of 10 (10 is easiest to repair) Battery is clearly intended to be user-replaceable (with built-in directions) and can be removed with the included Phillips screwdriver.
  • Nest Learning Thermostat 2nd Generation Repairability Score: 9 out of 10 (10 is easiest to repair)
  • Battery is clearly intended to be user-replaceable (with built-in directions) and can be removed with the included Phillips screwdriver.
  • Solid construction surrounded by a hefty steel ring makes for great durability.
  • Separation of components onto two motherboards increases modularity.
  • Light adhesive holds the front panel assembly together, slightly increasing difficulty of replacing the LCD or glass.
Hier Übersetzung einfügen
