Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard. Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard. Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
  • Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Hier Übersetzung einfügen
