Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4
Grasp the upper case near the back left corner and lift up partly so that you can access and disconnect the audio in/out cable from the sound card in the upper right corner of the case.
  • Grasp the upper case near the back left corner and lift up partly so that you can access and disconnect the audio in/out cable from the sound card in the upper right corner of the case.
  • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cable.
  • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
Hier Übersetzung einfügen
