Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Use a tweezer to slightly bent the logic board contacts on the USB connector. The purpose is to ensure a good contact when the USB connector will be applied against the logic board. In the first picture, you can see the contacts in the original position. In the third picture, you can see the contacts in the bent position.
  • Use a tweezer to slightly bent the logic board contacts on the USB connector. The purpose is to ensure a good contact when the USB connector will be applied against the logic board.
  • In the first picture, you can see the contacts in the original position.
  • In the third picture, you can see the contacts in the bent position.
  • Be careful, the contactors are fragile. Just slightly bent them.
Hier Übersetzung einfügen
