Englisch
Deutsch
Schritt 5 übersetzen
5. Schritt
There will be two small clips on each side of the motherboard. Using the plastic opening tool unhook each clip one at a time Once all four clips are unhooked you should be able to pull the motherboard from the casing using your hands. After you remove the old motherboard, you can then replace it with a new one.
  • There will be two small clips on each side of the motherboard. Using the plastic opening tool unhook each clip one at a time
  • Once all four clips are unhooked you should be able to pull the motherboard from the casing using your hands.
  • After you remove the old motherboard, you can then replace it with a new one.
Hier Übersetzung einfügen
