Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers. The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed. The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
  • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
  • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
Hier Übersetzung einfügen
