Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Using the Phillips #1 or Phillips #00 screwdriver, remove the two 3-mm screws from the card with black and white wires coming off of it. These are not captive panel screws and once loosened will be free to move about the assembly.
  • Using the Phillips #1 or Phillips #00 screwdriver, remove the two 3-mm screws from the card with black and white wires coming off of it.
    • These are not captive panel screws and once loosened will be free to move about the assembly.
    • Be careful not to allow either fastener into the CPU fan and duct (located in the upper left).
  • The card should pop up.
  • Gently remove the card with your fingers.
Hier Übersetzung einfügen
