Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Starting at its far right end, rock the clutch cover along its long axis while pulling it away from the clutch hinge. Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly. Lift the clutch cover up off the front bezel and set it aside.
  • Starting at its far right end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
  • Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
  • Lift the clutch cover up off the front bezel and set it aside.
  • When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
Hier Übersetzung einfügen
