Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass. Don't fasten the suction cup on top of the rubber strip around the edge of the display glass. To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
  • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
  • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
  • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
  • Slowly and gently pull the corner of the display glass up off the display assembly.
  • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
Hier Übersetzung einfügen
