Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 10 übersetzen
Schritt 10
During the glass removal process, the  AirPort & iSight data cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your AirPort & iSight data cable is still connected to the camera board, skip this step. If your objective is to remove the camera board, skip this step as reconnecting the  AirPort & iSight data cable is not necessary. To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the AirPort & iSight data cable ZIF socket.
  • During the glass removal process, the AirPort & iSight data cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your AirPort & iSight data cable is still connected to the camera board, skip this step.
  • If your objective is to remove the camera board, skip this step as reconnecting the AirPort & iSight data cable is not necessary.
  • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the AirPort & iSight data cable ZIF socket.
  • Use the tip of a spudger to flip up the ZIF cable retainer on the AirPort & iSight data cable socket.
  • Insert the AirPort & iSight data cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
  • Reapply the piece of tape covering the AirPort & iSight data cable socket.
Hier Übersetzung einfügen
