Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Locate the plastic tab next to the charging port and use a plastic opening tool to gently pop it out. Use the plastic opening tool to pry up the edges of the plastic casing.  You should be able to slide it around the edge to dislodge it. Use the plastic opening tool to pry up the edges of the plastic casing.  You should be able to slide it around the edge to dislodge it.
  • Locate the plastic tab next to the charging port and use a plastic opening tool to gently pop it out.
  • Use the plastic opening tool to pry up the edges of the plastic casing. You should be able to slide it around the edge to dislodge it.
Hier Übersetzung einfügen
