Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 10 übersetzen
10. Schritt
To remove the motherboard, gently pry it up with your finger from the charging port. Be careful not to yank the camera's ribbon cable as you lift the board.  Make sure that it is in line with its hole in the motherboard. Once the board has been lifted, remove it by pulling it away from the connected edge.
  • To remove the motherboard, gently pry it up with your finger from the charging port.
  • Be careful not to yank the camera's ribbon cable as you lift the board. Make sure that it is in line with its hole in the motherboard.
  • Once the board has been lifted, remove it by pulling it away from the connected edge.
Hier Übersetzung einfügen
