Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force. Insert a plastic opening tool between the edge of the bottom cover and the main body.
  • The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force.
  • Insert a plastic opening tool between the edge of the bottom cover and the main body.
  • Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
  • Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
Hier Übersetzung einfügen
