Zum Hauptinhalt wechseln
Englisch
Deutsch
2. Schritt
Using your thumb, applying constant pressure, pull back the plastic tab towards the speaker and away from the metal bracket. Simultaneously insert a Phillips #00 screwdriver into the square hole on the underside of clock and push through to lift the metal bracket off of the plastic tab.
  • Using your thumb, applying constant pressure, pull back the plastic tab towards the speaker and away from the metal bracket.
  • Simultaneously insert a Phillips #00 screwdriver into the square hole on the underside of clock and push through to lift the metal bracket off of the plastic tab.
Hier Übersetzung einfügen
