Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Step 1
Using a push pin, pull out the plug on the back, located under the antenna. You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  • Using a push pin, pull out the plug on the back, located under the antenna.
  • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
Hier Übersetzung einfügen
