Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 2
Orient the phone so that the edge closest to the camera points towards you and slide out the keyboard. Wedge the tip of a spudger between the keyboard and the display assembly below the camera. With steady pressure, pry the keyboard away from the display assembly.
  • Orient the phone so that the edge closest to the camera points towards you and slide out the keyboard.
  • Wedge the tip of a spudger between the keyboard and the display assembly below the camera.
  • With steady pressure, pry the keyboard away from the display assembly.
  • The keyboard and display assembly are glued together, so expect some resistance.
  • Do not completely separate the keyboard and display assembly because the display flex cable still connects them.
Hier Übersetzung einfügen
