Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove the 3.5mm screw holding the antenna guide in place with a Philips #00 screwdriver. Slide the antenna out to the edge, and remove the plastic tubing by gently pulling it out from the opposite end of the antenna.
  • Remove the 3.5mm screw holding the antenna guide in place with a Philips #00 screwdriver.
  • Slide the antenna out to the edge, and remove the plastic tubing by gently pulling it out from the opposite end of the antenna.
  • This step can be done after the motherboard is removed, or before (as photographed).
Hier Übersetzung einfügen
