Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 5 übersetzen
Schritt 5
Now, use the tire levers to wedge the tire off the other rim. This will be far easier than for the first rim. As you do this, make sure you pull the air valve out through its hole in the rim. Now, the tire (with the tube inside) should be completely removed from the rim.
  • Now, use the tire levers to wedge the tire off the other rim. This will be far easier than for the first rim.
  • As you do this, make sure you pull the air valve out through its hole in the rim.
  • Now, the tire (with the tube inside) should be completely removed from the rim.
Hier Übersetzung einfügen
