Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Use the two wrenches to loosen the nut that holds the brake cable to the braking mechanism.
  • Use the two wrenches to loosen the nut that holds the brake cable to the braking mechanism.
  • You might want to enlist a friend to hold on to the end of the cable for you so it doesn't fall off when you loosen the nut that holds it down.
  • Note: In this picture we use pliers and an adjustable crescent wrench in place of the 9mm wrenches that would be ideal for that bolt. However, anything that can turn the bolt should work just fine.
Hier Übersetzung einfügen
