Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Remove the blue wire by gently pulling. Disconnect the Brown cable. This is done by gently pulling the black tab away from the white plastic. This will loosen the tension on the brown cable allowing it to gently be slid away from the tab. Shown in the third picture, remove the 4 Phillips #1 screws connecting the circuit board to the optical drive assembly.
  • Remove the blue wire by gently pulling.
  • Disconnect the Brown cable. This is done by gently pulling the black tab away from the white plastic. This will loosen the tension on the brown cable allowing it to gently be slid away from the tab.
  • Shown in the third picture, remove the 4 Phillips #1 screws connecting the circuit board to the optical drive assembly.
  • The fourth screw is located behind the screwdriver in the third picture (highlighted in the orange circle).
Hier Übersetzung einfügen
