Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 6
Use a flathead screwdriver to release the two clips located on the back half of the drive assembly. The final clip doesn't need to be released; the top half of the drive assembly will slide away from the lower half. Finish removing the top half of the drive assembly from the base.
  • Use a flathead screwdriver to release the two clips located on the back half of the drive assembly.
  • The final clip doesn't need to be released; the top half of the drive assembly will slide away from the lower half.
  • Finish removing the top half of the drive assembly from the base.
  • Be careful not to detach the red wire or the white ribbon cable still attached.
Hier Übersetzung einfügen
