Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
7. Schritt
This job can be completed alone, but we used a second set of hands for picture taking purposes. Use a Zune opening tool to gently pry the inner chassis off the front case while simultaneously using another Zune opening tool to push the plastic clip near the control cable connector toward the inside of the Zune.
  • This job can be completed alone, but we used a second set of hands for picture taking purposes.
  • Use a Zune opening tool to gently pry the inner chassis off the front case while simultaneously using another Zune opening tool to push the plastic clip near the control cable connector toward the inside of the Zune.
  • Work your way along the media button side of the Zune to separate both clips securing the front case to the inner chassis.
Hier Übersetzung einfügen
