Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 21 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4
Lift up the front display bezel from the top and use your plastic card to free the tabs along the bottom edge of the display bezel. Make sure that your card is between the metal frame around the LCD panel and the display bezel and not touching the LCD panel itself.
  • Lift up the front display bezel from the top and use your plastic card to free the tabs along the bottom edge of the display bezel.
  • Make sure that your card is between the metal frame around the LCD panel and the display bezel and not touching the LCD panel itself.
  • After freeing all holding tabs, lift the front display bezel away from the display assembly.
Hier Übersetzung einfügen
