Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 19 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Step 3
Lift up the right side of the clutch cover and guide the display data and iSight cables through the gap in the clutch cover.
  • Lift up the right side of the clutch cover and guide the display data and iSight cables through the gap in the clutch cover.
  • Lift the clutch cover out of the display assembly.
  • During reassembly, make sure not to pinch the backlight cable (with the white connector on the right side) when snapping the clutch cover back into place. This cable has two visible wires leading into the lower right section of the LCD display to the backlight. (The models with pink and white wires are usually longer and easier to pinch.)
Hier Übersetzung einfügen
