Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4
Gently peel the inverter cable ground strap off the cast aluminum frame of the clutch hinges. While pulling the inverter cable away from its socket on the inverter board, use the tip of a spudger to push the connector out of its socket. If the connector won't budge from its socket, insert a metal spudger or similar tool into the gap between the connector and its socket and twist to separate the two pieces.
  • Gently peel the inverter cable ground strap off the cast aluminum frame of the clutch hinges.
  • While pulling the inverter cable away from its socket on the inverter board, use the tip of a spudger to push the connector out of its socket.
  • If the connector won't budge from its socket, insert a metal spudger or similar tool into the gap between the connector and its socket and twist to separate the two pieces.
Hier Übersetzung einfügen
